1990 DLX 3.0 Heater only working on low
I've been trying to figure out how to repair the heater in the truck I just bought. I replaced the blower motor and fan to start. (Originally nothing worked as far as the heater/a/c) After replacing the motor and fan it works on low speed. From my reading I'm guessing it's the actual switch or the weird coiled resistor thing. Where is the resistor/controller located??? Do you think that would be it? It's a 1990 Toyota dlx 5 speed, 4wd, ext cab.
Anyone have a switch for sale...they are like 35 dollars on ebay...paid less for the blower fan/motor. What does the relay look like? On a side note I replaced the door locks about an hour ago...pretty easy. I also taped off the holes with foil tape and added some dynomat I had left over since the panels had been off before and the vapor seal was missing.
If I was gonna sell one it'd be for $35 on Ebay
Try cleaning it, most likely burned back there. And make sure it's off when starting the vehicle or it supposedly gets overcurrent.
Relay is a black 1" cube in the block above the ECU, think it's the one towards the vehicle rear. Worth a look but if you have any power to the fan it's probably not the cause.
Try cleaning it, most likely burned back there. And make sure it's off when starting the vehicle or it supposedly gets overcurrent.Relay is a black 1" cube in the block above the ECU, think it's the one towards the vehicle rear. Worth a look but if you have any power to the fan it's probably not the cause.
zd92655
Mar 6, 2022 12:58 PM
Cesarl74
Apr 23, 2016 06:07 PM
