1990 clutch pedal no pressure and strait to floor
Old Jan 19, 2015 | 11:23 PM
focusmaniaczx3's Avatar
just wondering if these trucks run the hydraulic shifter shenanigans from the same reservoir as the power steering. the clutch pedal requires nearly zero pressure to push it to the floor and it wont go in gear. been having ps trouble lately and i was just curious to ask before i take a look tomorrow.
Old Jan 19, 2015 | 11:35 PM
Odin's Avatar
I don't quite understand that first part so I won't comment.
It sounds like you've got alot of air in the clutches hydraulic system. You should have a firm clutch pedal.
Old Jan 19, 2015 | 11:53 PM
wyoming9's Avatar
Red face
Your clutch master cylinder is on the left side of the engine bay in front of your clutch pedal.
Most likely it will be empty .
Something most likely has failed
Old Jan 20, 2015 | 01:50 AM
Terrys87's Avatar
They have two different reservoirs. I would suspect the clutch slave cylinder. Usually what fails from my experience. Check for air in the line.
Old Jan 20, 2015 | 04:23 AM
dropzone's Avatar
Fossilized
As mentioned checked the clutch master cylinder reservoir.
the slave cylinder will be on the right side of your bell housing.
if life is good with that check your clutch pedal for cracks
https://www.yotatech.com/forums/f116...fatigue-32667/
Just curious what vehicle uses the power steering system combined with the clutch hydraulics? ? Never heard of that before...seems like a bad idea.
Old Jan 20, 2015 | 04:26 AM
the miata from around the same year did. had something very similar happen to a friends miata several years ago and that was the issue. lost power steering from a really bad leak and within a few days it lost clutch as well.
i saw the sticky too btw. that will suck if that is the issue. i really hope its a simple track down the leak and add fluids fix. i hate working on cars in the cold and it wont get out of the 30s today...
Old Jan 20, 2015 | 04:31 AM
dropzone's Avatar
Fossilized
Ok.
So go check your clutch master cylinder and see if it has any fluid.
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Gone Fission
Jul 24, 2015 12:49 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
ptb12
Jul 5, 2015 01:49 PM
