1990 4 runner elec fan turns on and drains battery
Old May 5, 2016 | 08:36 AM
rockhounder's Avatar
Question 1990 4 runner elec fan turns on and drains battery
my 1990 4 runner suv elec fan is malfunctioning..when i turn the motor off it continues to run for hours. it also turns on when the motor has not been on for days..draining the battery. please advise me what the problem is and where to buy parts
Old May 5, 2016 | 01:36 PM
wyoming9's Avatar
Red face
These are your condenser fans for the AC ??
Contacts burnt and staying closed
Old May 6, 2016 | 07:56 AM
it is the electric fan behind the grill and in front of the regular motor fan. can i fix this myself? how?
Old May 6, 2016 | 09:32 AM
wyoming9's Avatar
Red face
Does Your AC work ??
If not just remove the fuse for the Fans or remove the relays.
That will not allow voltage to the fans.
Old May 6, 2016 | 12:14 PM
the ac works fine
Old May 6, 2016 | 12:26 PM
wyoming9's Avatar
Red face
Then your going to need to go through the complete fan circuit and see just where the system is getting power from
Is the truck Completely Stock ??
Any chance of hacked wiring ??
Old May 6, 2016 | 12:48 PM
i don't know the history. it has 300,000+ mi i have owned it 1 1/2 yrs this problem started 6 months ago. i replaced the battery. that didn't help.
Old May 7, 2016 | 12:50 AM
wyoming9's Avatar
Red face
It might be time to get some help any friends that know 12 VDC trouble shooting .
Is your ignition switch so worn your pulling the key out before it is in the off position ??
Bottom line the circuit for the condenser fan is staying energized because it is grounded
Wiring mishap ignition switch ?? Relay contacts on #2 Fan relay welded together
Old May 15, 2016 | 10:48 AM
horunner1x's Avatar
This happened to me. That thing mounted to the core support burnt out and ran my fan and actually melted itself. No part number and don't know what it was. So I just ran power to a rocker switch on my dash and flick the fan on when I run the ac.
Old May 15, 2016 | 05:25 PM
anndel's Avatar
I had a Flex A Lite fan on my 93 4x4 yota and though it had a thermostat that you mounted in the center of the radiator, it kept running then completely died. I returned it to Amazon.com for a refund. From what I've read about that particular fan was the control box that contained the relay was the problem and like Wyoming said, the relay contacts would be the issue. BTW, Mine was brand new.
aowRS
Mar 12, 2016 12:53 AM
Blake Carter
Mar 4, 2016 07:37 AM
Dustynyota_15
Feb 20, 2016 07:43 PM
Rapidrob
Feb 13, 2016 06:40 AM
