1988 Auto Tranny
Old 04-17-2008, 09:41 PM
Justinvd's Avatar
1988 Auto Tranny
Well i think my tranny has seen better days. Its the stock 1988 auto tranny, whatever bolts up behind the 22R-E. It started vibrating harshy when i would coast in o/d at higher speeds. So naturally i checked my u-joints, diff gear shape, driveshaft fase, drive shaft balance and everything is perfect. So i let it slide cuz i dont go fast very often. Now it does it in normal drive and o/d, its vibrating when i accelerate and coast and only stops at certain speeds and rpm. It recently started to shift really discustingly too, like weird shifts that make driving all but smooth, i dont accelerate fast either. And last symptom is that its starting to slip in reverse, sometimes it wont engage in reverse right away. My question to you guys is would a simple flush and tranny filter change cure this or help? ive never done much with tranny except change seals and ive done a clutch before, nothing internal. I just need to it last another month since im at school and only can do minor repairs right now. Any input would be great.
Thanks, Justin - i guess this is why they call it the "slush box"
Old 04-18-2008, 11:10 AM
Justinvd's Avatar
Is a tranny flush and tranny filter change worth a shot?
Old 04-18-2008, 11:39 AM
yotaman90's Avatar
It couldn't hurt, but I'm not sure if it would solve the problem
Old 04-18-2008, 01:00 PM
4runnerx3's Avatar
Unplug the ECT unit under the radio, it's the computer that controls the tranny. And do manual shifts. 1 will be 1st, 2 will be D, and D will be OD. You will not have 2nd gear because the shift solenoids are disengaged. This will let you know if you have electrical problems.
mskalmus
05-28-2017 07:51 AM
4x4-runner
08-03-2015 07:14 PM
Bucksnuff
07-31-2015 07:09 AM
Iceman4193
07-15-2015 04:48 PM
Quick Reply: 1988 Auto Tranny
