1986 4x4 sr5 efi 22RE
Old May 14, 2009 | 11:48 AM
schwany3131's Avatar
Hey guys i am new to toyotas....My freind has a 86 4x4 SR5 with the 22 R E engine in it witch i here is a damn good engine??? 150 thos on the engine. Its a 5 speed high/low it sifts like its brand new tranny and cutch are good. The box is junk its completly junk and rusted trough, the frame just has suface rust and still seems pretty soild.... It has bigger tires on it (wide track bajas) Looks nice!! The only problem is that it needs a new head gasket (witch i can change) but it poors antifreeze out the left front head..... common problem? I think i can get it for around 700 good or bad deal?? I really like this truck n Toyotas are the !! WEll some advice would be nice Thanks guys!
Old May 15, 2009 | 08:56 PM
anyone??
Old May 16, 2009 | 12:56 AM
wyoming9's Avatar
Talking
I think that is a little on the expensive side . i just bought a running truck with a lot of extra parts for less than that although it still needs work .
With the coolant leak you don`t know till you take things apart if there is any more damage . While you are in there use best do the timing chain with metal guides .
Plus all the other things that will need attention Brakes things like that etc .
That is my 2 cents
Old May 16, 2009 | 08:36 AM
Windsor's Avatar
There was a price?
150k on the engine is peanuts, they'll last 400k so long as there is minimal upkeep.
Like previously mentioned, find out the source of that antifreeze leak, that's not normal (or at least I've never heard of it after trolling this board for ~six months).
Old May 16, 2009 | 09:18 AM
blue_CA_yota's Avatar
I'd buy it for $700.. couple hundred bucks to do the headgasket in parts and machine work on the head, few hundred more on a box and you've got a "low imleage" truck for cheap.. its still cheaper than anything I'd find up my way (Toronto, Canada)
Old May 16, 2009 | 11:44 AM
okay thanks head gasket kit is like 100 bucks and that's all i should need right? I can deal with the box ill just rig something up. AND ya idk it like leaks out the front side of the head......it has a good oil pressure and dont suck oil...so rings are probably good...and wut else should i look for really? thanks guys and i thought 700 was cheap? for Yotas??
Old May 16, 2009 | 03:46 PM
yoterr's Avatar
yeah 700 is pretty darn cheap for a 4x4 yota, most peple wont let them go for less than 1500 reguardless of its condition, and like mentioned above, you might as well go for the timeing chain and guides (go with the metal chain guides) while your in there
Old May 16, 2009 | 04:34 PM
toyNG's Avatar
I'd buy it for $700. It's just a baby with only 150k
Old May 16, 2009 | 05:14 PM
Plumbrbob's Avatar
700?!?! pics?
Old May 16, 2009 | 09:22 PM
haha okay well i got it reserved already its my friends dads and i think he got it for free but i cant wait i have a lot of feuture plans lol !! well still a few hundred away from getting it but still............So now lets start with mods!? SOMEONE give me the lows down Thanks guys Zach
Old May 16, 2009 | 09:25 PM
toyNG's Avatar
Congrats!
Here is one of the most helpful threads on this whole site https://www.yotatech.com/forums/f120...mation-121264/
Old May 17, 2009 | 09:30 AM
Okay Thanks that was extremely helpful! Where is a good place i can get lockers and cheaper ones well cheaper
Old May 17, 2009 | 09:45 AM
Plumbrbob's Avatar
weld it thats the cheapest locker your gonna get
Old May 17, 2009 | 11:45 AM
toyNG's Avatar
welding is the cheapest. But there are some things to consider. First and foremost, do you have the means or know someone with the means of welding it properly? Second, is this mostly a trail rig?
A welded rear will chew up tires a lot quicker. If this is mostly a trail rig, then this isn't of much concern. But if it's your only means of transportation, you might want to reconsider. Nevertheless, I have some friends who swear that a welded rear drives better both on and off road than an automatic locker. Do some reading and research before deciding.
Old May 17, 2009 | 11:57 AM
olharleyman's Avatar
Sounds like the perfect time to FLAT BED IT.
Old May 17, 2009 | 01:17 PM
Plumbrbob's Avatar
Yup goes back to the same ole welded,spool,auto lock, selectable debate and everyone has different preferences.
Free traction = welded
I also know guys including me that will weld yours up for $50 or a case a beer and acouple cans of brake clean if you do all the wrenching and I'll do all the welding
Old May 17, 2009 | 07:15 PM
abecedarian's Avatar
not sure about needing lockers...
... having a friend with lockers and some tow straps to go wheeling with is a lot cheaper than putting lockers on your rig.
Old May 17, 2009 | 07:25 PM
ya idk ill be driving it on the street too and probably more then trails and mud we have more mud around here then anything so....
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
garagespace
Jul 9, 2015 08:37 AM
raiderhawks00
Jul 8, 2015 06:23 PM
