1 peice factory rear CV shaft???
Old Apr 7, 2008 | 11:09 AM
ccannon222's Avatar
Does anyone know which Toyota vehicles came with a 1 piece CV rear driveshaft? I’ve seen extra-cab trucks with 2 piece CV rears and I’ve seen a lot with CV fronts.
A couple years ago I picked up at 1 piece CV rear shaft at a salvage yard for free but I do not know what it came off of. I wanted to use it in the rear of my 4runner but the bolt pattern on the CV end is too large. I currently have a triple-drilled marlin flange. I also compared it to front output flanges and they are too small also.
Thanks
Chris
Old Apr 7, 2008 | 12:37 PM
Matt16's Avatar
Not sure what you're asking here. No Toyota truck or 4x4 (AWD excluded) has ever (and hopefully will never) come with independent rear suspension.
Are you planning on converting to independent rear suspension for some kind of desert pre-runner?
Old Apr 7, 2008 | 12:39 PM
norcalsvx's Avatar
i have a 1piece but no cv's on it, talk to your local driveshaft shop to get one made
Old Apr 7, 2008 | 02:18 PM
Bear80's Avatar
The rear part of the Tacoma or Tundra shaft is what you are after. They will bolt directly to the older trucks. The Tacoma shaft will need to be lengthened and the Tundra is pretty long but I don't think it's long enough. Also some driveline shops can't deal with the fused Tundra shaft, the Tacoma's are still welded.
Old Apr 8, 2008 | 08:07 AM
ccannon222's Avatar
Thanks for the replies.
Does anyone else know what model and year of any Toyota 4wheel drives that game with a 1 piece CV rear driveshaft?
I have 6 Toyota CV drive shafts that are different. 5 are fronts and 1 is a rear. I know what the fronts came off of and I am trying to figure out what the rear came off of. The junk yard wrote 4runner on it.
Thanks
Chris
Old Apr 8, 2008 | 09:36 PM
Bear80's Avatar
The '96-'03 4x4 automatic 4runners had the REAR double cardan joint drive shaft. Which a dead give away is the larger studs and pattern on the dc joint end and the smaller studs and pattern on the slipe yoke end.
I've gone through all this with my LC.
Old Apr 9, 2008 | 08:25 AM
ccannon222's Avatar
That sounds exactly like the DS that I am trying to identify.
Thanks
Chris
Old Apr 9, 2008 | 08:54 AM
just a 22re's Avatar
ok as far as what the junk yard said they wrote down your car not the one it came of of they never tell you what it came off of that way you have to go back to them and as far as toyota rear cv's here you go supra,celica (i think) , mitsu eclipse AWD, dodge neon AWD, and so on like that man and yes there is a dodge neon AWD its just not called a dodge neon AWD its in europe i think just look it up man
A2theK
Jan 10, 2016 10:18 AM
94whiterunner
9
Sep 22, 2015 07:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
