Will these tires fit?
Old Oct 16, 2007 | 02:39 PM
ydopen's Avatar
On my 85 I have 3 inch body and 2inch shackle lift. I am wanting to run some factory sr5 15 inch rims with 33x12.50 tire.I know the stock rim offset is inset and narrow thats why im asking THANKS
Old Oct 16, 2007 | 02:53 PM
85toy's Avatar
i think 33x10.50 will work but i dont think 12.50 will, but maybe, im not sure.
Old Oct 16, 2007 | 04:59 PM
navyredneck's Avatar
With a 3 inch body lift and stock suspension I am able to run 33x12.50 easily. I am pretty sure they will not fit on any stock rim, though. You need to look hard to make sure you have the right width rim to run those tires.
Old Oct 17, 2007 | 07:11 AM
dropzone's Avatar
Fossilized
Are your shackles 2" longer than stock? if so remember that on shackles you only get 1/2 the lift for the longer length of the shackle. But the shackle and BL should give you enough room with right rims.
If your stock rims are only 6" wide, than no. If they are at least 7" wide with enough back spacing.
Old Oct 17, 2007 | 12:37 PM
ydopen's Avatar
thanks I kinda figured the stock rims wouldn't have the correct offset to run a 12.50 wide tire but I was gonna get them powdercoated flat black and it would have looked good
Flying91
45
Apr 11, 2024 04:39 PM
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
coffey50
Jul 28, 2015 10:55 AM
