Will locker from 93 fit into 85?
Old 07-09-2009, 01:53 PM
JaredL's Avatar
I have an 1985 4runner solid axle that I would like to put a Detroit EZ Locker into from the rear of my 93 truck. Here are the specs:
1993 Truck, 22RE, 4.10 gearing, manual transmission, Rear 8 inch diff
going into...
1985 4runner, 22RE, 4.35 gearing, automatic transmission, 8 inch front diff
Can it be done (easily)
Thanks,
JAREDL
Old 07-09-2009, 02:00 PM
taconasty's Avatar
yes, it will fit. easily? thats up to your mechanical abilities.
Old 07-09-2009, 02:17 PM
89silverpu's Avatar
If they were the same gear ratios it would be as simple as swapping over the third member. The Lockrite itslef will fit in the 85, you'd just have to swap it over. I don't think you even have to redo the gears IIRC.
Old 07-09-2009, 03:46 PM
JaredL's Avatar
Thanks
Thanks for the responses. I will be keeping the truck (in fact, the original gears have been restored and the locker removed). By "Easy install" I meant that I won't have to do extra shimming/welding/etc.) It probably wont be an easy install for me since I have never done this before. The most that I have done was removed the axles and replaced the seals. Since I have to do that again, I figured I might as well slap a locker in there that otherwise has just been sitting around.
suppra87
07-15-2021 05:15 PM
choppe777
05-16-2016 08:00 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
old87yota
09-09-2015 12:39 PM
bootscootboogie
09-05-2015 05:57 AM
Quick Reply: Will locker from 93 fit into 85?
