When going .030" over, what piston to use?
Old Mar 22, 2007 | 08:01 AM
LUV24BY's Avatar
I am preparing plans for the build up of another 22RE for my runner. I am eyeing EB's kits, and for a bit of extra ponies I am going to have the block bored .030" (I was told .040" is the most the 22R blocks can have, so I want to save a little for future needs) Here is my delema-
I saw EB has some Turbo Pistons which I could realistically use. I won't be running a Turbo or a Supercharger, however I wish for about 175-200hp. I would like the piece of mind of the added strength and durability if the turbo pistons provide that.
Is there a noticeable difference in the way the standard .030" pistons and turbo pistons are made and there features?? If using the Turbo Pistons without a turbo, does that effect/lower the compression of the engine? I will probably be running a performance 22RE head. I would do the 20R head however the EFI I hear is not a bolt on to the 20R.
Thanks for the knowledge in advance!
John
Old Mar 22, 2007 | 10:09 AM
deserttoy84's Avatar
running turbo pistons will give you less compression. what you should do is get your 30 over pistons/rings and take em to the machine shop and them bore the cylinder to the pistons so you get the best clearences.
Old Mar 22, 2007 | 10:18 AM
LUV24BY's Avatar
That's what the machine shop wants me to do. I just thought the Turbo pistons would be a bit more stout, however if they give less compression then I will stick with standard style pistons.
Thanks for the info DT!
John
Firefightersink15
Nov 23, 2015 10:32 PM
charlie_fong
Sep 27, 2015 10:06 PM
sonorn67
Sep 19, 2015 05:39 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
old87yota
Sep 9, 2015 12:39 PM
