Weber problems
Old May 1, 2016 | 08:36 AM
Robbie82's Avatar
Weber problems
I have an 85 pickup 4X4 with a Weber carb. I'm getting fuel to carb but not in carb . Will only run when I pour had in the car. Can someone help me an d. Not sure what model Weber this is or how to tell
Old May 1, 2016 | 09:17 AM
dumpster84's Avatar
You sure you have your fuel lines hooked up correctly?
Old May 1, 2016 | 09:19 AM
dumpster84's Avatar
Also, not that it matters for this problem really, but the model of your weber is usually on the side, I think its on the side closest to the firewall, I could be mistaken.
Old May 1, 2016 | 11:18 AM
Robbie82's Avatar
OK now do you know anything of the problem im having
Old May 1, 2016 | 03:23 PM
dumpster84's Avatar
I already answered what it sounds like.......
Check your fuel lines and ensure they are routed correctly. It sounds like you might have them mixed up a bit. IF they are correct, verify that your pump is working. Other than that, I don't see what else it could be.
When you say you "are getting fuel to the carb, but not in the carb" where is it going? I don't see how that is possible. Is your carb super dirty and clogged up?
Joey22r
Sep 17, 2024 04:41 PM
msane99
Apr 29, 2016 03:16 PM
Theirons84
Apr 8, 2016 05:22 AM
msane99
Mar 16, 2016 12:40 AM
ToyMan62
Mar 5, 2016 07:11 AM
