weber 38 on 22r dieseling
Old Sep 6, 2006 | 06:18 PM
titicaca's Avatar
when i go to shut the truck off it diesles and sputters untill it finally stops. dxo you think i need da fue cut solonoid? where can i get one?
Old Sep 7, 2006 | 02:54 PM
Sonofmayhem's Avatar
do you think i need the fuel cut solenoid?
Old Sep 7, 2006 | 02:58 PM
4x4spaz's Avatar
Dzu ju sprecken ze english?
Old Sep 7, 2006 | 03:16 PM
titicaca's Avatar
ok let me rephrase that , do you think i need a fuel cut solonoid? simple question.
Old Sep 7, 2006 | 04:10 PM
titicaca's Avatar
i guess ill answer my own question , i had the idle set a bit too high and my idle mixture screw was set too rich on the primary side. i also had the timing set a few degrees advanced but i was able to go back about 1 degree after i set the idle mixture correctly. the weber instructions werent real clear about the adjustments , especially for the 38 which has 2 idle mixture screws instead of 1 like the 32/36 . now i get get a little better throttle response and no dieseling. thanks alot for all your helpfull advice ....
Old Sep 7, 2006 | 04:12 PM
4x4spaz's Avatar
No problem!
Pri$erulz
Nov 17, 2019 08:03 PM
user 82300
Jan 19, 2016 02:01 PM
highonpottery
Nov 22, 2015 03:57 PM
I8URSVT
Oct 5, 2015 05:42 PM
kawazx636
Sep 29, 2015 08:22 AM
