Transmission Oil Recommendation - W56
Old Jan 30, 2012 | 06:14 PM
redwolf3's Avatar
Holy dead thread revival batman!
As a note, I ran the manufacturer recommended fluid and have had no Ill Effects. I was having some stiff shifting issues before the rebuild when cold, but that must have just been due to the synchro's which were on their way out.
Old Feb 16, 2012 | 11:52 PM
dspan's Avatar
i see
Old Feb 16, 2012 | 11:55 PM
dspan's Avatar
Originally Posted by Subzero2cirb
85-140 + lucas oil stabilizer. Its thicker to help quite the trans and tcase down plus doesnt leak as easily and or let in water as well, I had an L45 and she was a GRowler put in 85-140 much quieter, then aded lucas even quieter and shifter smoother, no hard shifting ITS a toyota 4x4 trans for crying out loud not a maseratti these guys can use some thicker lube to help with the slack caused by abuse and high mileage. i also use it in my w56 now and even after my 4.7 install. the tcase even whines waay less with 85-140 and lucas now takes around 5-6 hours of solid wheeling to start whining at all.
Thanks for the tip, I am trying it this weekend. I have an H55F.
Old Feb 17, 2012 | 06:38 AM
2003mikem's Avatar
RedLine MT90
Old Jan 25, 2013 | 03:27 PM
  #25
Bullet22r's Avatar
i have a question about GL-5 gear oil whats wrong about using it? because my local auto parts store recommends it for my 1986 toyota 22r 4x4 pickup
Old Jan 25, 2013 | 03:43 PM
  #26
rokblok's Avatar
It contains corrosive additives that can/will eat the brass synchros.
Old Jan 25, 2013 | 04:41 PM
  #27
Mr.Utah's Avatar
It apparently corrodes yellow metals, like your synchros. Use the the gl-4 or some high grade stuff. Everyone will have their own opinion of course, but basic gl-4 cheap stuff works fine. I have been using Amsoil synthetic 75-90 gl-4, it has worked flawlessly from 0 deg to 110 deg/f. Its good stuff but pricey.
Old Jan 26, 2013 | 08:46 AM
  #28
Bullet22r's Avatar
okay thanks for the info guys
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
jjrbus
Jul 17, 2015 07:06 AM
ryerye13
Jul 14, 2015 08:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
