Top cowl panel how remove ?? Help
Old May 4, 2011 | 03:41 PM
nickwest's Avatar
Hi; Im still rebuild my 1989 HILUX XTRACAB; I've try to remove front top cowl but I've found only the two screw un the top, the COWL cant remove, there is other information I need?
Can someone explain me? Thank you
Thanks
Old May 4, 2011 | 03:45 PM
windedwalrus's Avatar
its probably just wedged under the windshield moulding make sure all the plastic pins for the weather stripping are pulled too
Old May 4, 2011 | 03:51 PM
nickwest's Avatar
Thank you; tomorrow I'll try to pull up the seal with a screwdriver to found the plastic pins.
Thank you WINDEDWALRUS
Old May 4, 2011 | 08:49 PM
sorry i ment the pins on the hood to cowl weatherstip. there isn't anything under the windshield crome (if i remember corectly) it should just pop up a little and slide out from under it.
Old May 8, 2011 | 08:00 AM
nickwest's Avatar
WINDEDWALRUS, thanK you; I've understood my mistake, on my cab there was only 2 pins; I think it was a rubber spaces between cowl and the seal hood, the other pins was already replaced by previous repaint work!!
Finally I have removed the 2 pins and the cowl!! Thank you again!!
Nick
Old May 8, 2011 | 04:06 PM
slacker's Avatar
save those "spacers" and reuse them . it will help the cowl from "vibrating" and causing unwanted noise .
also be sure to reuse the weatherstrip/seal undernieth the cowl front edge ..
should be 2 screws and 3 clips holding the cowl on
our smoothie cowl http://www.toyotafiberglass.com
westonian18
May 1, 2020 06:38 AM
jasonty
41
Dec 23, 2018 01:00 PM
rushw
Jul 18, 2015 01:46 PM
Iceman4193
Jul 15, 2015 04:48 PM
crashburnoveride
Jul 10, 2015 06:39 AM
