tire clearance issues
Old Apr 26, 2006 | 05:52 PM
ChaseHeadrick's Avatar
i recently purchased some 35x13.5x15 toyo m/t's mounted on 15x10 rims that i think are 3.75" backspaced. I am having trouble getting them to clear the frame in the rear, and the leafs(leaves?) in the front. anyway, if i just get a new rear axle from, say a 2nd gen runner, will that be good enough to clear the frame in the rear at full stuff? as for the front would the typical match of 1.5" spacers work? thanks for all the help.
Old Apr 28, 2006 | 05:29 AM
MtnToys's Avatar
widening front axle
look into placing ifs hubs on your front axle. you can upgrade your brakes with fj rotors and v6 ifs calipers at the same time. sky-manufacturing.com makes a kit with a spacer to do this for $200 but many people have done the swap without the sky spacer. this should give you an extra 1.5in on each side to match the width of the ifs rear axle you plan on using. i am planning to do this to my runner when i get a chance. it seems stronger/safer then a wheel spacer.
this thread has a bunch of info
https://www.yotatech.com/forums/show...ht=sfa+ifs+hub
Old May 4, 2006 | 05:23 PM
hey thanks for the info, i talked to a buddy of mine who happended to have some 1.5" spacers left over from his toy, so im going to try those.
Old May 6, 2006 | 09:23 PM
Oatmeal's Avatar
I've been running 1 1/2" spacers up front to match the width of my '86 rear end for about 3 yrs now without any issues. I torqued them in place with Loctite red on the inner studs/nuts and have never had to retorque them------Hans
Old May 7, 2006 | 09:25 AM
what size tires are you running?
Old May 7, 2006 | 09:37 AM
Oatmeal's Avatar
35x12.50x15s on 8" (3.75 b/s) steel wheels. I wheel it pretty hard and stuff them pretty good.....no clearance issues (the front end is moved 2" forward, though)-------Hans
Old May 11, 2006 | 02:42 PM
mine are 13.50's on a 10" wide rim. i clearanced the fenders, so im ok there, but i noticed they hit the leaf springs when im at full lock and the rears hit the frame when the axle articulates.
bigjstang
Jun 2, 2025 03:56 PM
Flying91
45
Apr 11, 2024 04:39 PM
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
