Timing Chain Question w/ Pictures!!
Old 09-03-2010, 06:29 PM
richf's Avatar
I just installed the oil pressure sender the one that goes on the side of the block. I got it from pepboys for around 40 bucks. Funny thing is I hooked it up were everyone says not to hook it up and now it works... I think or did I just complete the circuit and it will act like it is working? When I turn the truck on it goes up and when I turn it off it slowly goes back down.
A-ron do you have a online vendor for the TC kit? Should I just go to the dealer?
peow130's Avatar
Originally Posted by A-ron
22R are the noisest engines i have ever heard im sure its fine if you set the rocker lash
then you, sir, have never heard an L-Head 134..
Old 09-03-2010, 06:35 PM
toyota4x4907's Avatar
engnbldr.com probably has the best price for everything you need with quality parts.
xxxtreme22r's Avatar
or a BMW M30 engine like I got in my 535i. you think 4 valves tapping are loud, try 6 lol.
Old 09-03-2010, 06:40 PM
  #25
A-ron's Avatar
No I haven't!! I should have said "one of the noisest"
And Rich, go to www.engnbdlr.com great people great prices and free shipping!!!
Old 09-03-2010, 06:45 PM
  #26
richf's Avatar
Thanks I just checked out the website. I think I'll be good to go for about 140.00.
Do you guys think it's a bad idea to drive this thing around for any period of time?
  #27
i wouldn't
Old 09-03-2010, 07:03 PM
  #28
richf's Avatar
I just re-read the valve adjustment procedures and noticed the 22r is 0 degrees TDC and the 22re is 5degrees BTDC. i did not set it to 5 degrees BTDC I used 0 degrees TDC. Do you think that could cause more noise than usual? I'll have to re do it tomorrow.
Old 09-03-2010, 07:16 PM
  #29
E-ROC's Avatar
not sure of the quality or how long it will last but i got my TC kit from e-bay.came with guides, tensioner, chain, gears, and the TC cover all brand new for $57.xx total and free shipping. satisfies my budget right now.
Old 09-03-2010, 07:18 PM
  #30
na unless is was way advanced like 20 degrees or something like that causing an engine ping, timing wouldn't cause it.
BTW: what kind of exhaust setup you got on that, it sounds pretty good.
Old 09-03-2010, 07:20 PM
  #31
Where did you read that? I have always used 0* BTDC. Hm....
Old 09-03-2010, 07:22 PM
  #32
yes carb'd 22r's are 0 BTDC, EFI 22re's and rec's are 5 BTDC and 22rte,. I am not sure.
Old 09-03-2010, 07:25 PM
  #33
A-ron's Avatar
carb'd 22r uses vacuum advance, 22re uses electronic advance thats why you have to jump terminals to cancel the electric advance to set the timing
Old 09-03-2010, 07:29 PM
  #34
That's correct, and you also need to remove and block off the hoses to a carb'd dizzy. But this is not why the timing specs are different.
Old 09-03-2010, 07:46 PM
  #35
A-ron's Avatar
sorry, i should have explained myself a lil better, if a carb'd engine is timed at 0*TDC then the vacuum advance recconnected I believe it should read 14*BTDC as with EFI is timed with terminals jumped and set to 5*BTDC then terminals dissconnected it should read the same 14*BTDC.
And still this has always been my assumption so please correct me if I am wrong.
Old 09-03-2010, 08:31 PM
  #36
richf's Avatar
I saw the 5 degree btdc in the factory service manual I got on the web.
I'll post a video of the exhaust tomorrow. I'm not going to lie it sounds pretty badass. I have know idea what kind of muffle it is the PO put it on there.
Old 09-04-2010, 07:17 AM
  #37
So what you're saying is that when you set the engine to BTDC while adjusting the valves you're supposed to put it at 5* not 0*? Not the timing but while youre adjusting the valves?
Old 09-04-2010, 07:21 AM
  #38
no. crack goes to TDC on the 0 mark on the #1 compression stroke not the exhaust stroke, you will know it's compression stroke because the #1 intake and exhaust valves will be loose.
ignition timing is completely different.
Old 09-04-2010, 10:48 AM
  #39
richf's Avatar
I just double checked and on page MA-7 in the factory service manual it states 0 degrees TDC for tuning a hot engine. I was looking at tuning a cold engine during rebuild. I'm not sure if it makes a difference.
Old 09-04-2010, 12:53 PM
  #40
not for valves, not for ignition timing. hot or cold the crank gets put at TDC #1 compressionand and the ignition timing would still be 5 BTDC. with the diagnostic port jumpered.
Quick Reply: Timing Chain Question w/ Pictures!!
