timing chain questio,please help
Old Mar 10, 2007 | 02:36 PM
Jeenyus04's Avatar
timing chain question, please help
Hey, I have been rebuilding a 22r motor and when i put the new timing chain on from engnbldr it seems too tight. I had to use an adjustable clamp to squeze the chain together to put on the passenger side guide and the tensioner and now the chain has no slack what soever but they are on. Is there a chance I could have the wrong chain? I also rebuilt one about 2 months ago but that one blew a rod from the #1 cylinder and when i tore it back apart the plastic passenger side guide was completely worn out as well as the tensioner when it had the same "to tight" feeling. I could have been cause that motor ĊĊĊĊed up or maybe that chain really is wrong? it is the same chain i am using in this motor by the way.
thanks
Old Mar 10, 2007 | 02:58 PM
85TurboRunner's Avatar
what year is the engine, from 84 to 85 toyota changed the size of the block, 84 and older 22r's are taller and 85 and up are shorter blocks.
Old Mar 10, 2007 | 03:12 PM
Jeenyus04's Avatar
i dunno, the one i blew up was either 84 or 85 but didnt 84 motors have the double roller chain in them? I have a new block now though that i got from a buddy of mine an then had bored and hot tanked and im assumin its newer than 85 but he's had so many yotas that i really have no idea. the serial # is 3271197 can you tell by that?
Old Mar 10, 2007 | 03:23 PM
DeathCougar's Avatar
no 84 are not double roller. They are 1/4" or so taller on the deck heigth tho.
Old Mar 10, 2007 | 03:34 PM
Jeenyus04's Avatar
hmm well either way the rebuild kit was for a 85 + motor so then the chain has to be right? right? do you know how many links are in the chain for a 85 + motor? mine has 48 i believe.
Old Mar 11, 2007 | 03:37 PM
Jeenyus04's Avatar
anyone know how many links are in the chain for a 85 or newer 22r? mine has 48 but it feels tight.. you think it will just stretch? i had it in a motor that blew up after about a week due to a rod cap being backwards and it ate through the passenger plastic dampner and the tensioner. any imput?
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
