throotle positioning sensor sypmtoms?
Old Feb 29, 2012 | 11:00 PM
Npizzola's Avatar
1985 Toyota pickup fuel injection Automatic.
I just finished rolling new rod bearings in the old yotor and i go to fire it up it starts right up but then dies after a few seconds. i tried to keep it running with some throttle but it doesn't work. im throwing engine code 7 = throttle positioning sensor. my question is will my throttle positioning sensor cause my truck to do this...
Old Mar 3, 2012 | 02:34 PM
nashville67's Avatar
yes or the afm sensor it does this because it doesnt sense air moving so it wont add fuel i tried to start my 88 with the air intake line off and it would fire up and die every time
Old Mar 3, 2012 | 03:02 PM
toyospearo's Avatar
Pull the throttle body, clean it back to front sideways to sunday! While it's off pull the TPS and check it. Bring it back to spec via 4 Crawlers method and make sure and replace the phillips screws on the TPS to allen screws to make life in the future less of a headache!
Old Mar 3, 2012 | 04:46 PM
slacker's Avatar
if your trying to run it with out the air tube and AFM and filter box , forget it , it will throw the code .. you need to put it completly back together
Old Mar 4, 2012 | 11:54 PM
Npizzola's Avatar
thanks for the help!! i actually found the problem it was a ripped wire that went to the fuel rail! but next im gonna test/ replace the tps!
crammit442
7
Nov 29, 2017 12:30 PM
markwink
Aug 18, 2015 12:38 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
