third removal-leave brake lines attached?
Old Oct 7, 2013 | 11:04 AM
DBMorris's Avatar
Quick dumb question- can I pull my front and rear thirds out without removing brake lines ? Dont need to pull axles any farther then just getting them out of carrier. Its not a big deal, I just am trying to guesstimate the amount of time I need to accomplish a carrier swap in both ends. I did search but ran out of time looking and thought it may be easier to just ask.
Thank you in advance.
Old Oct 7, 2013 | 02:38 PM
rokblok's Avatar
There isn't much spare line to do it this way. I would just plan on removing them from wheel cylinder, then bleed when you're all done.
Old Oct 7, 2013 | 04:10 PM
eric-the-red's Avatar
I've done my rear and I don't think there is enough play in the hard lines. And anyway it isn't a good idea to leave the axles sitting in the tubes, they'll be sitting on the seals and possibly deforming them. While they're out is a good time to replace the seals anyway
Old Oct 7, 2013 | 04:41 PM
vital22re's Avatar
totally a bro
disconnect the rear wheel cylinders and cap them with vacuum caps.
Old Oct 8, 2013 | 07:43 AM
DBMorris's Avatar
Thanks guys, Now I know to check my bleeders prior to starting the project- if they snap I can make sure I have spares when I get going. I am limited on space so I need not tie up my only bay here for too long.
Sep 4, 2015 09:27 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
