these tires too big ?
Old Jun 4, 2012 | 10:28 AM
smartzombie's Avatar
hello all , just wondering if bfg km2 32x11x15 will be too big for a stock 84 Toyota pickup .. it has 31x10.5x 15 on it already ... thanks for the input everybody .
Old Jun 4, 2012 | 10:32 AM
matstaley's Avatar
They'll fit if you do the pinch weld mod. You'll be gutless if you don't re-gear.
Old Jun 4, 2012 | 10:35 AM
thanks for the info , apparently they don't make bfg km2 in 31x10.5x 15 ... any recommended tire size so I don't have to regear or mod the truck ?
Old Jun 4, 2012 | 10:36 AM
Elton's Avatar
http://www.tirerack.com/tires/tires....omCompare1=yes
Old Jun 4, 2012 | 11:05 AM
^^ thanks
Old Jun 4, 2012 | 11:16 AM
Bunk657's Avatar
I think you'll be able to squeeze them in there with a little trimming. It'll look good.
Old Jun 4, 2012 | 11:19 AM
thanks!
Old Jun 4, 2012 | 11:36 AM
James Woods's Avatar
SA trucks must have much less clearance because I run 32x11.50 tires on my stock IFS truck, no t-bar crank, no trimming or bashing and no rubbing. And with 32's on stock 4.10's isn't really all that noticable from 31's.
Old Jun 4, 2012 | 11:57 AM
andlours's Avatar
I have an '86 and I run 32x11.5 with no problems at all. I run the stock gearing and it drives fine. Honestly, you could run 32's fine. I say go for it and get the extra clearance.
Old Jun 4, 2012 | 12:32 PM
85toy4runner's Avatar
so the ifs trucks have more clearance than solid axle
Old Jun 4, 2012 | 01:36 PM
if I get a good enough deal I'll get the 32 "
Old Jun 4, 2012 | 01:54 PM
yoder519's Avatar
go for the 32s. I had 35 12.50s on a 85 with no life and a whole lot of trimming. I wouldn't worry about the gears everybody blows the whole gear thing out of proportion IMO. I run 35s on 4.10s. Its not fast, but it does ok.
Old Jun 4, 2012 | 03:32 PM
donomite49's Avatar
i ran 33x12.50 bfg at's on my stock 79 with flat springs like yours. rubbed only at full lock, a rough country 3" lift solved that problem. run em! i have had 32x11.50 on my 88 ifs truck with no rub.
Old Jun 4, 2012 | 05:37 PM
a buddy of mine is getting pricing on 32 " If I get a good deal I'll get the 32"
Old Jun 7, 2012 | 09:32 AM
TurboTruggy's Avatar
Some has done 36s with no lift, just start cutting !
Old Jun 7, 2012 | 09:33 AM
MaK92-4RnR's Avatar
buddy of mine has 32x11.5s on his 95 22re. he's doing fine with stock gearing.
Old Jun 7, 2012 | 09:34 AM
definitely don't want to cut .... plus it's my daily driver so have to be a little conservative ..
Old Jun 7, 2012 | 09:49 AM
donomite49's Avatar
yea don't cut anything no need with 32's. nice lookin yota btw.
Old Jun 7, 2012 | 10:10 AM
bob200587's Avatar
There's so much conflicting information in here.
Old Jun 7, 2012 | 10:32 AM
thanks ...
