surging at very light throttle
Old Jul 30, 2007 | 10:47 AM
markf's Avatar
I recently got my '85 22r 4x4 pickup running well again. Yes, my camshaft sprocket was off by 1 link. The problem now is, at veeerrrry light throttle, the engine surges. If I give just a little more gas it runs great, back off to just maintain speed and it starts surging again. The engine has about 50,000 miles on a rebuild. The vehicle did sit for about 2 years before last week and I had the carburetor rebuilt just prior to not using it. Gave it a complete tune up after it got running again. A number of things come to mind, varnish in the carb, clogged catalytic converter, old coil, any other suggestions?
Thanks,
Mark
Old Jul 30, 2007 | 12:17 PM
85toy's Avatar
bad gas? if it sat for 2 years that comes to mind.
Old Jul 30, 2007 | 04:59 PM
markf's Avatar
I put new gas in.
Mark
Old Jul 30, 2007 | 11:57 PM
the_supernerd's Avatar
My 4x2 did the same thing and it turned out that the steel vacuum line going to the main vacuum advance diaphram was cracked. I put a rubber hose in place of it to get it advancing again and it stopped surging. I would assume that a blown vacuum advance would cause the same thing. The main diaphram on the vacuum advance is the port closest to the front of the vehicle.
Old Aug 29, 2007 | 03:24 PM
Flash319's Avatar
I would also check your TPS.
Old Aug 29, 2007 | 03:30 PM
TACO626's Avatar
I dont think the 22r has a tps.
Old Sep 11, 2007 | 11:12 PM
Demon415's Avatar
If you have a tps it is going to be the problem. I had two of my 22re's that had this exact problem. Tps replacement was the fix.
Old Sep 11, 2007 | 11:20 PM
ozziesironmanoffroad's Avatar
hey, my truck does the same thing, but im runnin NEW gas in it. did you have any fuel economy problems? i put 2o in yesterday and got it to 3/4. now today i just got back from taco bell and its down at an 8th. i have a locking gas cap and it hasnt been disturbed. think the line might be cracked too?
Old Sep 18, 2007 | 06:09 PM
nspadoni's Avatar
is your egr working that would cause poor or no idle and surging
Old Sep 21, 2007 | 02:12 AM
When the vacuum advance was broken in my 4x4, I was averaging about 19 MPG and went up to about 22 MPG after I put a new one in. There are many things that affect gas mileage. Your truck might just need a tune-up, or it might have more serious problems. How does it run?
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
AkitaDog
Sep 1, 2015 08:05 AM
Dakotaneu
Jul 27, 2015 12:03 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
