Sterring wheel shakes and rear end popping??
Old Sep 9, 2006 | 10:24 AM
deserttoy84's Avatar
OK i got some issues right now and i dont know to much about these push pull steering systems yet still. when i got about 45 or so the wheel shakes left and right. into corner its very noticeable. What might be causing this? also when i start to accelerate from a stop there is a pop somewhere in the rear. it doesnt do it every time but it does it a lot. am I looking at u joints? If it makes any difference on the steering issues i run 33s. I really want to fix it and so my truck feels solid. thanks
Old Sep 13, 2006 | 06:33 PM
leiniesred's Avatar
Wheel balance is the shakey shakey left and right thing.
not sure on the pop in the back. check ubolts on rear axle, t-case mount, and then think about a broken spider gear in the diff or maybe a broken tooth on the ring gear.
Old Sep 13, 2006 | 08:13 PM
titicaca's Avatar
most likely its ballance, likely the tread seprating , excess moisture in a tire that big will really cause problems. ditch the push pull and go with histeer....
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
Daneums
Aug 20, 2015 05:36 AM
toyoda8488
Jul 5, 2015 10:18 PM
