sr5 dashboard clock
Old Jan 26, 2006 | 06:56 PM
darth brian's Avatar
sr5 dashboard clock
so i got a digital clock out of my bothers 4runner that bolts right onto the dash. looking at it, it has 4 wires on it. im assuming that red is power and black is ground, duh. the other wires are green and white i think. one of them has to be a power to ignition, one has to be constant, one had to be ground. but i have no idea which ones are which and what the 4th wire runs to. anybody know?
Old Jan 26, 2006 | 06:57 PM
JamesD's Avatar
One if for the dimmer. I dont know which one it is though.
James
Old Jan 26, 2006 | 07:38 PM
89macrunner's Avatar
red is constant black is yoru ground (dur)
for some reason i think green is ignition and white is dimmer but i ahve no idea
Old Jan 26, 2006 | 09:57 PM
if the dimmer isnt plugged in would it work and be on full brightness or be on the lowest brightness, or even show up at all
Old Jan 27, 2006 | 05:58 AM
rudestar's Avatar
Feel around behind the clock opening. All wiring harnesses have a clock plug. It may be taped down to main harness trunk.
Old Jan 27, 2006 | 07:48 AM
Flamedx4's Avatar
You beat me to it.
Old Jan 27, 2006 | 10:24 PM
i cant find it. could it be by the sterio head unit or behind the glove box?
Old Jan 28, 2006 | 02:45 AM
freshman's Avatar
if you open up the dash clock, just unclip the sides, it is labeled inside the 4 male connectors.
Old Jan 28, 2006 | 05:57 AM
ironroad9c1's Avatar
yea its already wired for the clock ,because alot of em where dealer installed items its ther e behind the ashtray and radio somewhere pull off that center cover and look for it .
Old Jan 28, 2006 | 11:01 PM
i couldnt find it so i just made/ran my own wires in. after playing with it for 10 minutes with aligatorclips i have the offical results:
green wire= dimmer
white wire= ground
red wire= ignition power
black wire= constant power
got it all hooked up and it looks sweet
Old Jan 29, 2006 | 11:40 AM
Flamedx4's Avatar
Good job!
But just for the record, you should avoid using the multiple-choice alligator clip method of testing with anything electronic - this quite frequently releases the magic smoke from it and it never works again.
Old Jan 29, 2006 | 04:02 PM
what do you mean? that it will blow/fry things up?
Zach_trun
Nov 17, 2015 07:56 AM
longbed
Sep 16, 2015 10:35 AM
Rawwdz
Sep 6, 2015 09:03 PM
seab1209
Sep 3, 2015 05:41 PM
