spark plug smoking
Old May 21, 2006 | 10:26 AM
slammdrider's Avatar
spark plug smoking
just put new spark plugs and wires on and now for some reason one of them is smoking what would cause this problem.
Old May 21, 2006 | 03:27 PM
fo_runner's Avatar
Are you sure you tightened the spark plugs all down correctly? (don't overtighten)
Old May 21, 2006 | 05:45 PM
midiwall's Avatar
2nd'd... There's a compression washer on the plug that needs to be - compressed - in order for the seal to work. The washer will provide a good bit of resistance when you're tightening down the plug, but not as tight as when the plug is actually torqued up.
Be careful, you can over-tighten the plug, but you do have to make it through the initial resistance of the washer before things will work right.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
defrag4
Jul 31, 2015 10:50 AM
JefferDean
Jul 31, 2015 10:39 AM
