shackle reverse
Old Aug 13, 2009 | 10:43 AM
desertcamper67's Avatar
Originally Posted by yotaman84
actually i meant leave it front wheel drive and get out? ya pull your rear out but i would be worried about not getting all the shards out and taking out my other set. idk just me tho
and thanks
To give an accurate answer, the rear is only a semi floating axle. So the axles support the weight of the vehicle somewhat. If it was a full floater I could have just pulled out the axle shafts and removed the rear drive shaft and drove out in front wheel drive. You can't just take out the 3rd member and expect the axle ends to stay put in the center of the housing. Not to mention the gaping hole that would be left in the front of the rear housing collecting everything that kicks up on the trail.
If it happened on the front I would just unlock the hubs and IF I needed to use low range I would also take out the front drive shaft to eliminate the broken gears trying to mesh.
I hope that makes sense. Sorry about the long answers.
Old Aug 14, 2009 | 05:40 AM
dropzone's Avatar
Fossilized
saw this pic of a recent jeep run on the rubicon, front mounted shackle came apart after dueling with rocks...sure it could happen to any rig,
thought it was kind of cool
Old Aug 19, 2009 | 11:35 AM
cblackard's Avatar
ok guys im looking for some thoughts on this. i have an 84 xcab that im swaping a dana 44 in the front and am looking for some lift options. right now im kind of thinking of doin a shackle reverse and runnig stock rears in the front and i have chev 63's in the rear. anyone done this? thoughts and opinions welcome anything you guys got would be awesome thanks
Most of the jeepers like to swap the shackles to the rear of the front springs for better steering control on road. Also eliminates the beating they take up front.
I'd stay with the Yota axle up front unless you are looking for a wider axle. The Yota front axle weak point is the birfield joints, but its still a pretty stout piece overall.
CB
Old Sep 3, 2009 | 01:05 AM
LIVES4CRAWLIN91's Avatar
Originally Posted by desertcamper67
I don't blame my breakage on the size of my r&p. I blame 4Wheel Parts who put it in. I found the pinion nut loosened up after a year and they wouldn't do anything about it. They didn't even peen the nut into the slot and no cotter pin is used. I just tightened it and peened the nut over.
It was a poor install job if I ever had one.
My truck has the 22RE and that isn't enough to break stuff like that on the ledge I was attempting.
you know that's ironic cuz i have a 1990 4runner sased. 3.4 swap and blew the ring and pinion. (so i thought) further inspection concluded that the ring gear bolts had backed out and believe it or not 4wheel parts are the guys who set up the rear 3rd
oldblue
Sep 28, 2015 04:07 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
Ricu_air
Sep 19, 2015 05:35 AM
scheuvront1993
Sep 17, 2015 06:17 PM
May-39
Sep 6, 2015 01:05 PM
