Seized pistons
Old Feb 26, 2012 | 03:31 PM
85RunnerSR5's Avatar
Seized pistons
I found a 1st generation 22r long block behind my neighbors house in the woods. It appears it has sat for years in the weather. I tore it all down but can't get the pistons out. From what I could tell, it appears that someone stuck a pry bar in one of the cylinders and hammered on it to get the piston out of the cylinder and failed, which makes me think that they let it run hot and seized the engine.
Is there anyway to get them out? Or should I just scrap everything for a decent block? I sprayed PB blaster on it and let is soak then tried to hammer them out but they wouldn't budge. Any suggestions would be helpful.
Old Feb 26, 2012 | 03:39 PM
rokblok's Avatar
I think if it's seized that bad, I would discard it. You will probably do irreparable damage if you attempt removal of the pistons more than has been done already. Although it would probably piss me off and make me more curious so I would do everything I could to get them out....
Old Feb 26, 2012 | 04:32 PM
lethe's Avatar
scrap it and find a block that hasnt been sitting in the elements for a few years.
Old Feb 26, 2012 | 06:44 PM
skoti89's Avatar
pics or it didnt happen
Old Feb 26, 2012 | 07:25 PM
vital22re's Avatar
totally a bro
soak and heat them up
bigger hammer.
Of course I wouldn't use that block... but for giggles why not get them out?
Old Feb 26, 2012 | 07:49 PM
yeah I agree with you guys...I'm gonna find another donor. Thanks for the input!
ladybugRC
458
Aug 21, 2020 10:41 AM
Firefightersink15
Nov 23, 2015 10:32 PM
charlie_fong
Sep 27, 2015 10:06 PM
old87yota
Sep 9, 2015 12:39 PM
seab1209
Sep 3, 2015 05:41 PM
