It seems my 88 4x4 V6 needs rebuilt
Old Mar 21, 2019 | 09:44 AM
Scott Corbiser's Avatar
I'm in no hurry but I want to make this truck right. It only has 66k miles on it but I assume the original owner let it sit so long that it damaged the engine. Do you think a complete rebuild or just just heads need rebuilt the compression is good. Though the picture shows concerns. This a picture of the throttlebody open.
Old Mar 21, 2019 | 09:47 AM
The truck is a 88 3vze 5sp 4x4
Old Mar 29, 2019 | 12:33 PM
SENOR NOODLES's Avatar
1988 is the worst year for the Toyota v6. I would find a 89 and up 3.0 to rebuild. 1988 had an issue with the block cracking under the freeze plugs at the top of the engine. Magnuflux will not present these cracks because of the location.
Old Mar 30, 2019 | 06:03 AM
rattlewagon's Avatar
Compressions good? Does it knock at all? What makes you think the engines bad? Seafoam it to get all that gunk out. Then run it.
Old Apr 1, 2019 | 08:07 PM
thefishguy77's Avatar
Seafoam or a 1/4 quart of ATF in the oil. Drive it for 50 miles and change it? I use whatever of the 2 are handy to get a quick clean on the inside.
Chick-N-Picker
Jun 23, 2017 07:04 AM
Rymer22
Jul 25, 2013 09:27 AM
cw733
Apr 11, 2010 10:33 PM
idanity
Nov 11, 2007 08:51 PM
n8inks
Aug 8, 2006 12:35 PM
