Which rims and tires....again.
Old Mar 4, 2007 | 11:10 AM
ToyYoda's Avatar
I have an 85' solid axle pickup and I am unsure which rims and tires combo I can get away with. Searching pulled up a bunch of newer IFS answers. I'm going to buy 15x8 rims that have 4inches of backspacing and was hoping to put 35x12.5x15 size tires. Is it possible without rubbing? I have a 4 inch. suspension lift only.
Old Mar 22, 2007 | 06:07 PM
mudtoy's Avatar
hey, I have a 85 reg cab, solid front axle myself with 3" body lift, I deal with wheels and tires for a living, and I have 15 x 10's and have used 35 x 14.5 on them with a little rubbing, but opped for 33 x 11.50 thornbirds, or 33 x 12.5 will work fine, only possible rubbing would be on the little lip on fenderwell at door, no biggy though. 35 x 12.5 on a 8" wheel is a strech but lots of people do it.
Old Mar 22, 2007 | 06:39 PM
LUV24BY's Avatar
When I went to have my 325/60 15's (basically 31x12.50 15's) mounted on my 15x8's, Discount Tire wouldn't mount them. They said I needed at least a 8.5" rim for them to do it. So, instead of spending $70 to have 4 tire off and 4 tires on w/ balancing - the only place I could find to do it was Sears Auto Center and they charged me $140 to do the job that Discount said would be $70;
My point is that I would double and triple check places to see if they would even mount a 12 1/2" tire on a 8" rim.
John
Old Mar 22, 2007 | 09:25 PM
slabcrawler's Avatar
I'm sure you will rub the bottom rear corners of you front fenders and also the rears will hit on the frame on the inside of the tire when flexed. I would go with a 2 or 2.5 inch BS. I thought 2 inch BS was going to look funny because the wheels stuck out so far but I love it now! If our going to 35's you should widden your stance.
Old Mar 23, 2007 | 01:42 AM
ToyYoda's Avatar
3.75 is what I went with and they are a bit too far in for me. I'll probably get some wheel spacers. I can't find rims with less than 3.75 inches of backspacing. Doesn't matter though...I love the ones I have now.
chukarhunt
Dec 8, 2019 11:39 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
Cycles
Sep 29, 2015 06:37 AM
Bill McBride
Sep 20, 2015 02:51 PM
AkitaDog
Sep 3, 2015 09:01 PM
