Removing rear window key cylinder?
Old Jan 7, 2008 | 05:10 PM
Mr Maraki's Avatar
Looks like somebody jammed a screwdriver in my rear window key cylinder. Can't roll the window down via that switch, works fine from the front switch.
I tried taking it out, pulled that license plate trim it's attached to, undid the two screws that mount the cylinder to the trim but it's attached on there somehow that I can not figure out for the life of me.
Looked in the FSM, no dice (or I can't find it). Anyone know how to get that bad boy off?
Old Jan 7, 2008 | 08:33 PM
FamRunner's Avatar
Lock cylinder
I just did this on 4runner there is a hole on the side of the cylinder by one of the hold down tabs if you use a small punch and push in the pin and pull the cylinder away from the trim piece it should pop right off
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
icentropy
Jul 9, 2015 02:12 PM
ItsJustD
Jul 7, 2015 07:49 AM
coryc85
Jul 6, 2015 04:07 AM
