Removing Front 3rd Member
Old Jun 18, 2009 | 09:09 AM
Ultimate's Avatar
I found a write up for removing the rear 3rd member and I am having trouble finding one for the front. I am in the process of doing this right now so any help asap is appreciated.
Old Jun 18, 2009 | 09:15 AM
UKMyers's Avatar
Need your rig information. If it's a 90-95 Truck or Runner here's the directions straight from the FSM
http://personal.utulsa.edu/~nathan-b...20removalo.pdf
EDIT just noticed what section you posted this in. If it's a solid front axle it's the exact same as the rear except pulling the axle shafts involves a little bit more.
Old Jun 18, 2009 | 09:18 AM
TOYOTA 1's Avatar
8" front also?
hubs and spindles need to come off. and the birfs/inner axles need pulled out a few inches.
Old Jun 18, 2009 | 09:20 AM
Ultimate's Avatar
1985 4runner
Old Jun 18, 2009 | 11:23 AM
Teuf's Avatar
ifs stinks for flex, remove sway bar
Old Jun 18, 2009 | 11:43 AM
toyNG's Avatar
How was this statement at all relevant to this thread?
Old Jun 18, 2009 | 12:06 PM
UKMyers's Avatar
What is going on around here lately?
Old Jun 18, 2009 | 04:57 PM
Teuf's Avatar
oops wrong thread
Old Jun 18, 2009 | 07:00 PM
desertcamper67's Avatar
This would be a great time to replace that little axle seal in the knuckles. Since you're pulling the axles out a little, pull them all the way out and the seal is right there. If they don't leak now they probably will soon.
Old Jun 19, 2009 | 12:27 AM
Wardamneagle's Avatar
...and I would use the Marlin Crawler heavy duty front axle seal as long as you are replacing it.
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
