Rear axle seal
Old Jul 18, 2010 | 08:46 AM
Bad_Bowtie_ssz71's Avatar
Rear axle seal
Noticed this morning my rear axle in my 84 4wd is leaking gear oil from the hub. Brake drum is full of grease. Not sure what part(s) I need to fix never done one before. Just replace outer seal or inner and bearing?
Old Jul 18, 2010 | 09:03 AM
waskillywabbit's Avatar
You need one of these kits (per side)
http://www.wabfab.org/Rear-Axles/Rea...ypage.tpl.html
Old Jul 18, 2010 | 11:09 AM
2DoorRunner's Avatar
And just because i know its gonna be asked...
http://www.4x4wire.com/toyota/mainte...wheel_bearing/
Old Jul 31, 2010 | 04:30 AM
fourtrax's Avatar
just a thought... the breather port on the axle might be clogged with mud or something causing preasure to build up and push out the seals.
Old Jul 31, 2010 | 07:31 AM
Lysmachia's Avatar
Well if the diff breather is clogged, yes it needs to be unclogged but the axle seal damage is done, so those need to be fixed as well. Do you have a Diff breather extnsion on?
Old Jul 31, 2010 | 04:19 PM
slacker's Avatar
as above ..
sometimes the diff breather is the cause .. if it is `cloged` the pressure will have to vent somewhere else , so usually its the pinion seal , but i have seen the axle seal `go` as well .. but 9 times out of 10 , it is because of the axle bearing is worn out ..
replace the bearing .. if you go to a bearing store , you can get them for $25.00 + an outer seal for about 5 bucks ..
If your brake shoes are soaked in oil .. you will need to replace those as well ..
hope that helps
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Iceman4193
Jul 15, 2015 04:48 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
