is a Puller needed to remove axles from the housing (SA)
Old Feb 9, 2011 | 11:24 PM
SC81YOTA's Avatar
Is there any reason at all why you should have to use a puller to get your axles out of your housing. It seems to be a struggle with my set up. Any info is needed. Birfeilds are lined up the knuckles. thanks for the help please!
Old Feb 10, 2011 | 12:02 AM
scuba's Avatar
No reason at all really. As long as the flat spot is lined up with the birf indent it should easily pull out. Have you tried hitting it with your purse?
Old Feb 10, 2011 | 01:22 AM
myyota's Avatar
Are you sure the axle housing isn`t bent ?.
Old Feb 10, 2011 | 03:53 AM
dropzone's Avatar
Fossilized
Just an FYI-I am going to tweek your thread title...your "Why should you have to?"
is not specific to your thread and per the rules could have led to deletion with out notice.
X2 on the bent housing
Old Feb 10, 2011 | 04:37 AM
waskillywabbit's Avatar
If you have to beat in the axles with a hammer or use a pulled to remove them your axle housing is bent.
:wabbit2:
Old Feb 10, 2011 | 10:11 AM
SC81YOTA's Avatar
Thanks for all the input. I know this is talked about in my other thread but figured I could get a better response on that particular subject by starting this one. Picked up my new housing last night. Got one from an 85 model. Hope to be wheeling again soon.
Old Feb 10, 2011 | 10:14 AM
SC81YOTA's Avatar
[quote=ocdropzone;51656769]Just an FYI-I am going to tweek your thread title...your "Why should you have to?"
I'll read through the rules again.
Ichneumon
Sep 27, 2015 04:21 PM
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
