Oil and water temp
Old Oct 17, 2011 | 06:31 PM
cbr600rx7's Avatar
Oil and water temp
Just wondering where you guys are taping into to get good oil pressure and water tempiture readings. I have a few gauges sitting around from old projects and figured why not add them to the toyota.
Old Oct 18, 2011 | 07:06 AM
ant27's Avatar
my oil pressure was in between the motor mount bolts on the pass side
Old Oct 18, 2011 | 04:23 PM
cbr600rx7's Avatar
Is that where the factory oil pressure sensor is? And if so did you just use a T fitting to tie into the oil supply.
Old Oct 18, 2011 | 05:16 PM
ant27's Avatar
its not the factory place on mine. the factory one is behind my oil fliter. i used a after market mechanical unit from napa. it came with a couple of different fittings and luck one fit.
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
