Oil pan question - paper towel left in pan when sealed up
Long day and I was tired. I don't remember specifically removing it so a dropping I will go. Boneheaded, but at least I hadn't filled it with oil again.
All you have to do is jack the frame about an inch or so to clear the axle with the oil pan.
Dealer price out is $266 to r/r. Yes Im lazy but not THAT lazy.
Im going to see if I can snake it with a coat hanger through the drain plug first as it is right above it. Might get lucky.
I am either at the dealer or talk to them every day...so I asked just out of curiosity.
The easy way to make FIPG a multi-use tube is to attach the spout extension, cut just the tip off, then stick a screw in the end. That way even if the stuff hardens in the tube, it won't be hard at the actual tube.
Sep 4, 2015 09:27 AM
