Is an oil cooler really neccessary?
Old Apr 30, 2007 | 08:13 AM
ewong's Avatar
sort of - Im running an OBERG 6" commercial filer instead of an oil filter.
use an oil filter adapter with AN hoses to the filter which has be relo'd to the front fender area (in front of the wheel). It acts as a pseudo cooler. Have a therostadt to plumb in line but after running a temp guage, decided I didnt need to add the cooler.
Old Apr 30, 2007 | 09:49 AM
mike92runnerSR5's Avatar
I guess I'll do a search for B&M or some other brand aftermarket. Can't really afford another $415. Price has doubled already for this orig. HG job.
Old Apr 30, 2007 | 10:24 AM
ewong's Avatar
Yer in Hudson Valley NY - so you have "winters".
Dont wanna run a cooler w/o a thermostadt...
Old Apr 30, 2007 | 10:37 AM
yea we usually have winters...I'm sure they'll come back sooner or later...w/thermostadt....got it. you know now that I look at the diagram off alldata looks like it may run coolant through..I'll try and post the diagram..I guess it is a heat exchanger type
Old Apr 30, 2007 | 12:34 PM
  #25
well I can't seem to post the diagram but it looks like either coolant or oil flows from one tube into the cooler then back out into the block.
Old Apr 30, 2007 | 02:37 PM
  #26
has anyone else bipassed/eliminated and/or used an afternarket oil cooler?
Old Jun 29, 2007 | 05:57 PM
  #27
mt_goat's Avatar
Originally Posted by Trumpfan
I used an adapter that sandwiches between the block and the oil filter, it has a simple theremostat in it already. Made up some aeroquip hoses at work but a good quality rubber hose and worm clamps will work fine too.
What brand adapter did you get that had a thermostat built in? Did it fit ok?
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
this_guy
Jul 31, 2015 01:27 PM
calderp
Jul 27, 2015 09:58 AM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
