oil cooler?
Old Jan 26, 2009 | 01:04 PM
live4soccer7's Avatar
oil cooler?
is there anything of such sort on the 22r engines? I have an 85 4x4 yota
Old Jan 26, 2009 | 01:13 PM
deserttoy84's Avatar
Nope... but one can easily be added. just get a remote filter kit for a regular ford v8 (ph8,s8 etc filter) and plumb one in between the output of the filter and input of the adapter.
Old Jan 26, 2009 | 04:12 PM
not interested in putting one in at the time. Just trying to find how coolant is getting into my block. Either b/c of the timing chain or a head gasket. In the process of tearing down right now
Old Jan 26, 2009 | 04:25 PM
Hayes's Avatar
I'd say head gasket.
Old Jan 26, 2009 | 06:03 PM
86tuning's Avatar
sometimes a bad waterpump will groove the timing cover enough to allow coolant to leak through.
Remove the waterpump and CAREFULLY inspect with a bright light. If you see scoring, replace the cover, they're cheap, and available from a few aftermarket sources.
Old Jan 26, 2009 | 06:07 PM
hauckster's Avatar
have the same problem here and it was the head gasket.
but new motor was my fix cause i needed new piston rings and all the seals
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
this_guy
Jul 31, 2015 01:27 PM
calderp
Jul 27, 2015 09:58 AM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
