not getting fuel?
Old Dec 21, 2008 | 12:04 PM
algranger's Avatar
not getting fuel?
ive been battling this issue for a while now, my 22r runs fine at idle but if you give it any gas it just quits instantly. last night i took apart the carb, soaked the jets and a bunch of other parts and cleaned it up real nice still the same problem. i even tryed an extra carb ive got layin around still same problem. so does anyone have ideers?
and yes i replaced the fuel filter
thanks!
Old Dec 21, 2008 | 12:13 PM
86tuning's Avatar
There's a window in the front of the carburetor that you can check with a flashlight that shows fuel level inside the bowl. It should be in the middle of the sight glass. If not, you have a fuel delivery problem, ie, filter, pump, etc.
On my truck I put a clear motorcycle fuel filter after the pump, before the carburetor, so that I can monitor the fuel flow. If I see bubbles in the filter, I know my main filter is plugged :o
If your fuel level in the carburetor is good, then you likely have blockage in the jets, which requires minor disassembly of the carburetor, and cleaning with stiff wire and/or compressed air, along with plenty of carburetor cleaner.
HTH.
Old Dec 21, 2008 | 05:28 PM
algranger's Avatar
brand new filter and pump ill look into it more maybe ill throw on one of my spare pumps
thanks
Old Dec 21, 2008 | 05:38 PM
scuba's Avatar
that sucks
Old Dec 21, 2008 | 07:03 PM
algranger's Avatar
Could it be the timing advance?
Maybe something ignition related?
Anyone?
Old Dec 21, 2008 | 07:08 PM
scuba's Avatar
Someone on heres gotta have some advice to help out my buddy
Old Dec 21, 2008 | 07:11 PM
algranger's Avatar
thanks man... maybe if we give it like 200 posts people will be like hmm that looks popular ima check it out
Old Dec 21, 2008 | 07:19 PM
4runnermt's Avatar
My old '84 did that, but it turned out to be the fuel pump. Did you check your ignition components? Cap/rotor, plug wires, coil? I'm just trying to think of some possible culprits..
ttlycnfuzd's Avatar
Just a simple thought, but how sure are you of all of the vacuum lines? I would think that if you had timing issues, that it would grunt & sputter, not die completely. Fuel or air probs seem like an easy start.... I could be wrong tho... Anyone else?
Old Dec 21, 2008 | 07:25 PM
algranger's Avatar
i checked them when i put em on about 2 weeks ago. i wonder if the dist. slipped a little bit and its way off time ima go check. when i got the donor motor for this truck it had a brand new fuel pump but maybe its bad. ill try an older one i know it good.
i dont know the vacuum system too well but i know everything is hooked up i have a perfect running identicle truck to compare vacuum to and it matches up good.
the reason i thought it could be ignition timing is cause as your rpm's speed up, there is a vacuum operated advance, since the pistons are moving faster it must spark earlier and if thats disfunctional then it will run fine on 5% at idle but not at higher r's
Old Dec 21, 2008 | 07:34 PM
ttlycnfuzd's Avatar
Does disconnecting the advance change anything? Now im interested as to what this could be....
Old Dec 21, 2008 | 07:44 PM
algranger's Avatar
i donno ill go and see. im gonna watch the viewing glass while it runs, check the timing, check the plugs, disconnect the advance and try a different fuel pump ill be back on soon
Old Dec 21, 2008 | 07:57 PM
myyota's Avatar
Check the cacuum advance, they can go bad and cause problems, and its a very expensive part to replace. i had to replace one on an 84 4Runner 22R that i used to own.
Old Dec 22, 2008 | 12:47 AM
algranger's Avatar
ok heres what i found.
timing was about 3% after tdc.. waaay late. so i adjusted that and it started running a little better. then i soaked the carb in spray carb cleaner and gave it a few revvs. a little better. then i took it for a little drive and its running great for about 15 mins so i open it up in a feild and then all of a sudden it quits. just like that. nothing. same problem again. im stumped.
timing is good its getting fuel and spark carb is rebuilt what else could it be??
Old Dec 22, 2008 | 05:56 AM
scuba's Avatar
The fact that you have a carb...
ahah...You know im always gonna give you crap for that..
that blows man..
EFI FTW !!!
Old Dec 22, 2008 | 11:11 AM
algranger's Avatar
anyone?
Old Dec 22, 2008 | 11:20 AM
ttlycnfuzd's Avatar
OK... well.. lets assume for the moment that the fuel delivery side is fine (new pump, filter, reb. carb). That should only leave one other thing - spark delivery system. What is the condition of your plugs/wires/cap/rotor? Have you checked for any loose connections?
- Just throwin out ideas... as stumped as you are
Old Dec 22, 2008 | 11:25 AM
algranger's Avatar
loose connection is very possible. the plugs are pretty dirty but they wouldnt cause it to run perfect then not run, then run perfect, then not run again it happened so suddenly it makes me think there could be a short somewhere. cap, wires, and rotor were good a few weeks ago when i put the motor together but ill go check them
Old Dec 22, 2008 | 11:34 AM
algranger's Avatar
all ignition related and carb related connections look good. im about to check the cap and rotor.
Does anyone know if i can put an early model 22r (84) vacuum advance on the late model 22r (85)
ttlycnfuzd's Avatar
The only other thing that might be.... what about the pickup for the coil itself (points/electronic... whatever)... possibly testing that. Altho, if you were able to read your tach, which uses that signal, probably not....
- Tryin to think of other ideas
