new third member
Old Mar 14, 2015 | 07:25 PM
furlong24's Avatar
new third member
I am buying a complete kit 5.29 gears and ARB locker, but i was wondering since i am switching the 3rd member out can i switch to running a HP in my 4cyl 8" housing?
Old Mar 14, 2015 | 07:29 PM
furlong24's Avatar
my tuck
currently I have an 85 Toyota pickup 4cyl. i have a 3" lift installed but a 4" at thwe house waiting to go in. I just ordered the low pinion 3rd member for the front, but got to thinking if i could hae oredered thr high pinion for the 4cyl *' straight axle housing
Old Mar 14, 2015 | 07:35 PM
JasonYota's Avatar
Yes you can run a high pinion 3rd in the front axle. But you said you already bought a low pinion? Kinda to late now.
Old Mar 14, 2015 | 07:38 PM
furlong24's Avatar
I just placed the order this weekend, so I can call and change it. Is there anything special I would have to do to convert my 85 straight axle into the high pinion?
Old Mar 14, 2015 | 08:39 PM
furlong24's Avatar
I just find it weird that the HP would bolt right into the 4cyl 8" housing no issues, and the complete HP thrid isnt cheap so i just want to make sure there isnt any issues or instructions that i am missin. I have been searching for answer but always seems to never be straight forward.
Old Mar 14, 2015 | 08:44 PM
dropzone's Avatar
Fossilized
It will bolt right in, with 5.29's you may have to rotate the ring gear slightly when you install it
I believe the high pinion requires a different gear set than standard thirds.
Are you having someone set up the gears for you?
Setting up gears is kind of an art from IMO, especially when throw an ARB and routing the inner copper tube..
Old Mar 14, 2015 | 08:46 PM
furlong24's Avatar
It is the complete third member from low range offroad, so it is all assembled. Okay i will give them a call and switch to ordering the high pinion
voiddweller
Oct 2, 2015 07:47 AM
toyotasaurus
Sep 24, 2015 03:30 PM
