Need a plug for power steering pump
Old Oct 14, 2010 | 12:03 AM
turnr's Avatar
Hi guys. First time here.
I am using an early 80s Toyota pickup power steering pump and steering box on my 54 Ford pickup project to add power steering. There is a fitting on the pump with vacuum hoses that I believe go to the carb. I want to plug it but cant find a correct plug. I tried an inverted flare to AN adapter with a cap. The inverted flare would not make a seal against the mating surface in the pump. The threads bottomed out before the sealing surfaces made contact. Any ideas about the correct plug I need? Thank you
Bob
Old Oct 14, 2010 | 12:52 AM
myyota's Avatar
You might be able to find a plug at the parts store, or use a very short bolt with a copper washer or something similar and that should work. Just remember the threads are metric.
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
bryan34w
Jul 6, 2015 05:53 PM
elwood73
Jul 5, 2015 07:07 AM
