Need help with brakes
Old Jul 1, 2008 | 04:21 AM
tacdeg's Avatar
I changed my front brakes. I took the lines loose at the calipers. I put them back and cant get any pedal. I tried to bleed them over and over. I still have got no pedal at all. Please help.
Old Jul 1, 2008 | 04:33 AM
crews462's Avatar
Did you bleed the rear brakes as well. Not always necesary when you've been working on the front, but you should do the rear as well
Old Jul 1, 2008 | 05:32 AM
Wardamneagle's Avatar
There is a great search function. It's in the upper right, "search forum". If you search for: brake bleeding, you will find quite a few threads on the subject.
Try reading this one:
https://www.yotatech.com/forums/f115...brakes-107617/
Good luck.
Old Jul 1, 2008 | 05:43 AM
CJM's Avatar
CJM
Why did you remove calipers to change the brakes? 2 man method, 1 pumps other loosens screw. Over and over and over. If you want the master out your sol though.
Old Jul 1, 2008 | 05:48 AM
zlathim's Avatar
If, during the time you were bleeding them "over and over" you let the master cylinder go dry, you now have air throughout the system. Bleed everything according to the instructions in the link above.
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
