More Responsive Steering?
Old Jan 12, 2012 | 01:08 PM
1985runner's Avatar
Sorry if this question has already been asking somewhere i've searched multiple times and can't fnd anything.
I have an 1985 4runner with TG Hy-steer and a lengthened steering column / boxed in frame done professionally. For some reason my steering is super un-responsive and i can never get the steering wheel aligined straight.
I've tried fixing it many times but nothing really works, any suggestions?
Old Jan 12, 2012 | 01:55 PM
Sensei's Avatar
We'll assume it's power steering or it could be manual, which is it ?
By unresponsive do you mean steering input is delayed or non-functional ? Steering wheel alignment is done at the same time toe is set. Have you set your toe-in ?
Old Jan 12, 2012 | 02:35 PM
1985runner's Avatar
Its a steering box off an IFS truck, so yes it has power steering. Steering input is delayed and literally to go straight the steering wheel has to be turned 1/4 turn to the right. I have taken the steering wheel off multiple times to correct it which lasts for a few weeks then becomes un-aligined.
Old Jan 13, 2012 | 08:48 AM
GEOz2k7's Avatar
ifs trucks came with no power steering to. just so u know. and u should rly take it in to a alignment shop then. something is rly not right. are ur knuckles rebuilt? have u tightened ur steering box? its a 17 and u turn a flat head i believe. helped me before. do u have a steering stabalizer. i dont run high steer yet but many of my buddys do and i have worked on them all. if the steering wheel itself is moving. after driving around. is it itself loose? u can take a shim out of the top n bottom of ur knuckles to tighten them up also. just some info. lemme know!
Old Jan 13, 2012 | 11:31 AM
4Crawler's Avatar
Sounds like your pitman arm is not centered on the box:
- http://www.4crawler.com/4x4/CheapTri...html#Alignment
That and it could be the caster angle is off. Too little and you lose the "return-to-center" steering. This is common if you have dropped the front spring hanger.
kawazx636
Oct 6, 2021 03:03 PM
gentry
Sep 28, 2015 06:16 AM
Kylenicoll33
Sep 17, 2015 08:40 AM
89hilux1
Sep 14, 2015 06:13 PM
128keaton
Sep 3, 2015 05:09 PM
