Missing, Knock CEL, Hesitation ~1800-2400RPM
Old May 23, 2017 | 03:07 PM
andykrow's Avatar
Did you jumper the test plug when you did your timing? Timing should not be moving around that much when jumpered. With the test connector in you want 5 degrees BTDC. But if you are at 5 without the test connector in the timing is retarded much to far. Should read around 12 in normal idle operation (un-jumpered) but that can vary.
A friends truck behaved this way when the timing was way off, like ATDC. Turned out we had a bad timing light.
The vac hose off the dashpot is normally connected to a tiny air filter. It should not have actual vacuum on it.
Old May 23, 2017 | 03:20 PM
Saiba Samurai's Avatar
Yeah I have it jumpered when I set it. I testing my timing light, it's working fine. I don't think it jumps around all that much.. 4-6 degrees
If you take a look at my latest pictures.. I'm replacing my injectors this week. If that doesn't fix the issue I'm not sure what I'll check next. :/
Old May 23, 2017 | 04:01 PM
85TRD4runner's Avatar
While I think replacing the injectors is necessary and will help, looking at the wiring in your photos tells me you have a lot more to fix and diagnose.
Old May 23, 2017 | 06:06 PM
Wish there was someone nearby that had a clue how to do it.. because it's outside my skill set. Any idea what that bottom connector is for? I know the wire would be impossible to tell me.. but the connector seems fairly unique.
Old May 24, 2017 | 08:22 AM
  #25
andykrow's Avatar
Hmm i wonder if your total advance is messed up? Have you looked at timing without the connector in? I have heard there are a lot of early ECUs that advanced way too far and cause the miss you speak of.
That's a tough one on the wiring. Mine has some extra A/C wires hanging out unconnected, even though my truck never had factory A/C.
Old May 24, 2017 | 10:56 PM
  #26
While in my driveway the timing seems fine, under idle and when I give it some RPMs.
I put in new injectors today, going to redo the injector connectors. Still trying to figure out what the empty connector is. I think the single wire is for the A/C compressor that it not hooked up.
Old May 25, 2017 | 05:08 PM
  #27
Thanks for the help everyone! I re-did the wiring today and replaced the injectors. No more miss!
