loose belt noise but belts are fine?
Old Apr 21, 2010 | 07:43 AM
GranVille-4crawler's Avatar
So on my way to work today I was noticing that I have a belt noise that wasn't there yesterday... sounds almost like a belt slipping or a squeaky pully. I'm supposed to drive my rig down the interstate tomorow... don't need anythin givin out on me... the noise is not super loud but you can hear it over the engine and my exhaust. I've examined the belts... no wobbly pulleys... any ideas? 1985 22re with ac. Does the noise even if the compressor isn't enganged. It sounds like is from right around the fan area?...
Old Apr 21, 2010 | 01:40 PM
toyota4x4907's Avatar
Well start by taking each belt off one at a time, starting it up and seeing if the noise is there to determine which belt system it is coming from.
Old Apr 21, 2010 | 06:16 PM
85-in-va's Avatar
most of the time its the powersteering pully that bolts right to the head, and what he said^^^
Old Apr 21, 2010 | 06:34 PM
PlanB's Avatar
I have a similar noise coming from that area. (85 4Runner 22rec) Thought it was the tensioner pulley. Pressed a new bearing in there. Wasnt it... Now Im pretty sure its my water pump. Thats right behind the fan. Squeels intermittent, but usually right when I shut it off. You might see a little moisture coming from the weep holes on the water pump.
dinks07
Jul 15, 2015 05:34 PM
mengquis
Jul 13, 2015 10:39 AM
cars-guy
Jul 11, 2015 07:51 PM
nick b
Jul 11, 2015 04:38 AM
Poncho0206
Jul 10, 2015 06:21 PM
