Leaking clutch fluid
Old Jul 13, 2007 | 05:03 AM
G's 84 Runner's Avatar
I've been needing to refill my clutch fluid almost daily. I think I need to replace my Clutch Master Cylinder. Could it be anything else? I haven't had the time to isolate the leak, but any hints on where to look would be a great help.
Old Jul 13, 2007 | 05:47 AM
myyota's Avatar
Look under the dash were the shaft comes out of the clutch master cylinder, if you can see or feel fluid comming out of the master cylinder its bad. I had to replace mine last week because it was leaking. also check the slave cylinder that operates the clutch, they can also leak .
Old Jul 13, 2007 | 05:50 AM
waskillywabbit's Avatar
Typically you replace both together.
Clutches:
http://www.wabfab.org/products/clutches/clutches.htm
jasonty
41
Dec 23, 2018 01:00 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
gmonnie123
Jul 26, 2015 02:44 PM
the1998sr5
Jul 16, 2015 06:20 AM
Rkellerman
Jul 12, 2015 08:42 AM
