larger front brake conversion help
hi guys im having issues on my front brake conversion .
i have a 85 extended cab pick up with high steer and 6 bolt TG knuckles .
but to add a monkey to the mix now the front axle is now a 83 front due to total damage playing in the mud up here bent into a smiley lol
so seeing as im swapping all my goodies over i wanted to also beef up front brakes ..
and ran into a issue im using 95 4 runner rotors and brakes but also found i had to use the hubs due to mounting holes lining up on hubs to rotors .
my 83 axle is too small of a pattern .
they mounted on spindles great but now calipers are a good 3/4 inch off from mounting point on knuckles .
i think im using wrong spindles due to offset any ideas?
thanks
wayne
thanks
wayne
i might be wrong aain looking at axle it looks to be 79-80 front axle because the rotors have 6 bolts holding them on spindles guess id need the 79-80 fj rotors now with ifs hubs and caliper ..
is this correct ?
is this correct ?
89-95 IFS V6 Calipers
81-90 FJ60/FJ62 Rotors
79-85 Stock SFA hubs/spindles
That is what you need.
thanks for the skinny !
i had it all ass end back wards i had to order rotors no part houses in town had any so its a few day wait now till i get it finished .
for northern alaska it aint bad lol
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
