Just finished changing timing chain in previously sealed motor- wont run!!!
Old Dec 16, 2011 | 06:23 PM
fbi96743's Avatar
Delete please. Double post
Old Dec 17, 2011 | 02:20 AM
skypilot's Avatar
Ok; you got the mechanical timing off.
First check spark, make sure you have a spark at the plugs, no spark, no fire. Check fuel, make sure its wet with gas and it should at least stumble & spit if you have spark.
Could be the distributor, or it could be the cam. You need to mechanically check both by setting the crank to TDC #1 and checking both valves are closed & the dist. is pointing twards #1 on the cap. If it is; run a compression test and it should be above 100. If not, fix it, since its not going anywhere like that. Then walk the engine over and verify the exhaust valve opens at 200 degrees rotation from TDC. If its the intake that opens, your camshaft is 180 degrees out. Fix it, its not moving.
Check the build threads for more information. lots of info for fixing just this issue.
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
hexrain
Jun 27, 2015 06:17 AM
Badger62811
Jun 26, 2015 09:26 PM
