Junkyard frankenstein alternator.
I finally got another 4runner after not having one for a few years. I got an 85 that needs love. It's a southern truck , so no rust!
The alternator was bathing in power steering fluid and decided to take a dive. I didn't want to spend ~$100 on a rebuilt one, so I cruised the local Pick n Pull. Toyota trucks are non-existant there, so I looked for something close that I could make work.
After a bit of trial and error, I found that an alternator from an 89 Acord LXI is the same case as our 85+. The pully is differant, but the shaft is the same diameter. The voltage regulator is a 4 wire, but I changed it to the three wire regulator from another one I had. It only takes 4 small bolts and 5 screws to change.
I found a car with a very oily engine and a shiny alternator. It still had the rebuild sticker on it. So I got a rebuilt alternator for $17.00 and a little work.
I might do a wright up when I do a spare soon.
Anthony
Anthony
theking11863
Mar 19, 2016 09:36 PM
LotOMiles
Sep 14, 2015 11:45 PM
alt, alternator, alternators, frankenstein, frankensteins, junkyard, make, pick, pull, term, w4small, wire, yotatech
