? on installing trail gears 4" lift springs
Old Feb 23, 2006 | 04:44 PM
slider_buck's Avatar
i bought a set of 4" springs along with 5.5" schackles. the springs don't have wedges built into them to help correct the pinion angle. it includes a left side shim which i guess is used for clearing the drag link, right? what's the best way to get my pinion back down? should i cut off the factory spring mounts and relocate them?
Old Mar 6, 2006 | 08:52 AM
YO38's Avatar
You have to cut the spring perches and shock mounts off the axle and rotate the pinion up. then tack every thing Be sure to double check the pinion angle before welding every thing up. Tom Woods Driveshafts can send you a little card that you can use with a string and a plum bob to set your pinion angle. They diddent charge me any thing to send me one. Also dont heat the axle housing up to much it could become brittle in that spot and have an increased chance of breaking or bendin, just take your time with it.
Old Mar 8, 2006 | 10:03 AM
fourwd1's Avatar
Do that more than a degree or two and you'll screw up your caster, which creates steering problems. That's why you have to cut and rotate the knuckles also if you do what's suggested above. Caster is more important than pinion angle.
The 4" lift springs start the problem and the longer shackles compound it. Try it with the stock shackles before doing anything drastic.
Or you could buy some shims (what you refer to as wedges) to correct the problem.
Old Mar 23, 2006 | 08:22 AM
rrmike's Avatar
The shim is for the drivers side because the spring perch on the pass side is built higher and most aftermarket springs don't compensate for that.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
