Inner rear axle seals
Old May 24, 2009 | 11:42 AM
TOY84OTA MAN's Avatar
Exclamation Inner rear axle seals
hey guys i got an 84 Yota pickup single cab, and i dont know what it is but what keeps on making my rear inner axle seals go out??? this is the secound time ive replaced them! im prietty sure its the rear inner axle seals..because i smell gear oil all over my brake shoes.....and no rear brakes!!!
Old May 24, 2009 | 11:52 AM
TOYOTA 1's Avatar
bad wheel bearings, or a groove worn in the axle by the seal.
Old May 25, 2009 | 09:41 AM
DoveGray85's Avatar
Also the shims on the top and bottom of the steering knuckle center the axle shaft. If it's not centered, the axle seals will wear out faster. The FSM calls for special tools to get the axle shaft centered. I don't know how it's done at home typically. So just having the pre-load set using a fish scale is not enough. For one thing, add or subtract shims equally on top and bottom.
I just did mine, and I'm not sure if my axle is centered. I had to remove shims to get the pre-load right. One thing that will help is to use the Marlin inner axle seals. They supposedly allow for the axle shaft to be slightly off center. I hope.
Old May 25, 2009 | 10:00 AM
TOYOTA 1's Avatar
hes talking about the rear, not the front.
Old May 25, 2009 | 04:15 PM
DoveGray85's Avatar
Oops! My bad. I've heard that the front inner axle seals can be a problem too and they're way harder to get at.
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Iceman4193
Jul 15, 2015 04:48 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
