Idle surge when braking.
Old May 18, 2015 | 02:17 PM
theduck21's Avatar
85 sr5 4x4 pickup with 22re 5 speed. I have the idle screw seated all the way with white tape on it and new o ring, the idle control thing is blocked off and when I spray starter fluid there are NO leaks. Yet it will not idle down past 1100 rpm and after it warms up and I come to a stop the idle surges but when I let off the brake it idles normal but still 1100 rpm. Brand new tps adjusted correctly. Dashpot is gone. Any ideas what the deal is?
Old May 19, 2015 | 06:30 PM
YotaWoRx's Avatar
Sounds like the auxiliary air valve is stuck open either due to blocked coolant lines going to it or it's faulty itself.
smthwsn357
May 1, 2024 07:28 AM
wafoogalla
Nov 2, 2016 11:02 AM
PBRaddict#1
Aug 22, 2015 11:34 PM
bighaydn
Aug 4, 2015 07:17 PM
Dakotaneu
Jul 27, 2015 12:03 AM
