idle questions!
Old May 6, 2015 | 01:52 PM
theduck21's Avatar
idle questions!
Almost have my 85 sr5 pickup ready for the road but I have some questions about the idle. It idles at 1100 rpm and won't adjust any lower is that okay or too high? Also when I come to a stop the idles jumps between 500 and 1100 rpm but when I let off the brake pedal it goes back to normal. Any ideas? Thanks!
Old May 6, 2015 | 06:05 PM
bobpat's Avatar
if you turn the throttle body idle screw down to the stops it still idles high? If so it is sucking air in, you should be able to kill the engine adjusting that screw all the way in.
Old May 6, 2015 | 06:48 PM
theduck21's Avatar
That's what I thought but I've sprayed carb cleaner all over and no difference in idle speed
Old May 7, 2015 | 01:15 PM
dimitri's Avatar
You want to check the idle screw's o-ring. Mine was baked and the screw was turning waaaay too easily.
I also replaced the vacum lines attaching to the throttle body and sprayed TB cleaner into the vacum port opposite of the TB (I used the port for the Power Steering pressure valve)
All this seems to have calmed it down to ~950-1000 instead of the 1500-1800 it was idling at before.
Old May 7, 2015 | 01:49 PM
Terrys87's Avatar
Is the bolt that is on the Dash Pot too high? I have seen that before, not letting the throttle close all the way. It can get loose.
Old May 8, 2015 | 10:30 AM
theduck21's Avatar
Dash pot is gone
Old May 8, 2015 | 10:50 AM
DavidLovesToyotas's Avatar
Dash pot is what keeps it from stalling when you let off the gas suddenly and slowly drops the rpms. Id look into getting one for your throttle body.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
